um-fpu coprocessor
hi there all,
got the um-fpu floating point coprocessor to do some number crunching with my sx-48, and cant seem to get the right numbers back out..
anyone used these b4 ?
i've got it hooked up via I2C.... should i use spi ?
still working on it , but thought i'd drop a question here, will be good to know someone has done it b4 with sxb
dan
dan
Jon Williams
rewired it for SPI, looks good now,dont know why it didnt want to do I2C
but now i have a numbercruncher [noparse]:)[/noparse]
dan
Are you using it for that? And if the answer is 'yes', will you be integrating your calculatons with a real-time clock?
It seems everytime someone has an Astronomy project, they merely focus on the number crunching, but it they are really going to apply this robotically to control the movement of a telescope it seems that they have to sync the calculation iterations to a time period.
Having an autonomous clock may compensate for delays or other glitches.
Post Edited (Kramer) : 1/27/2006 3:20:25 PM GMT
there is a addon mod that i could get for the sawmill that does the job, but its $1500 and since the sawmill is a hobby now, and i have manufactured hydraulic componets for it, i thought i would just play with making this componet....
so far i have got it to work with the sensor, and with the UM-FPU using spi ( still having trouble with some of the functions ) now i'm going back and doing the keypad to enable me to enter commands
precision with that sensor is like 2200 counts ( roughly) for 24 inches, right now im using to the 1/16th of a inch, could go to 1/32 but the mill doesnt need that precision yet.. using the timer on the sx48 btw..
anyways,· thats what im playing with currently, just got in the ic2/uart eval board and musing on it
dan
Would you mind posting your code ? I'd love to see it.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
Anything more is unneeded as wood shrinks and expands with humidity. Even at 1/32nd, the wood must not be green in order to take advantage of such.
I assume this is rough cut, rather than trying to get a smooth surface. That is usually provided by a planer.
Post the project too, if you care to share. I lived in Eugene, Oregon for 15 years and originally there were 20 saw mills of a wide variety. These days, only two remain.
A small mobile mill can go into the forest and really achieve a lot. You can mill all the lumber for a rural home on site and then just build it in a few months.
in the tree. (I've seen some boards bend 6 inches over 8 feet when cutting wet lumber)
However, once the wood is properly dried and the good stuff is selected and planed, a 1/32 is a mile!
At least for furnature work, anyway. FYI, the lift for my router has 1/512th inch resolution!·(And it repeats to that!) Also it·is not unusual to use a·micrometer 1/1000th for measurements of stock thickness. However, shrinkage and expansion due to moisture change can be .020 in/in from winter to summer.
Wood is·a fun change from MCU's...·· ...At least·you can·sand off bits that don't fit.·I'd like to see
someone sand off the extra bits in an MCU!
-Dan
on 12 hour nights right now so no time for experimenting, but heres the original code, without the Um-fpu, in it you can see where i am integrating the keypad... its a 2x 8 matrix so it will be a lowprofile box
its unfinished, but the code parts for the linear sensor using the timer and outputing to the lcd work right now
dan
