Advice on codes
Hi !!
· I have wriiten the following code and will like to seek advice on whether they look functional and correct, before i put it on trial on my airplane.
· Basically what I need the program to do is for the parallax microprocessor to
read in 2 signals from the reciever unit (Channel 2 and 5). If channel 5
is 'Off', the processor will simply pass on the signal read in from
channel 2 to the elevator servo unmodified. On the other hand, if channel 5 is
'On', then the processor will ignore the signal read in from channel 2,
and follow its preset logic to send the necessary signal to the servo.
· Thank you !
Regards
Wilson
· Thank you !
Regards
Wilson
bs2
5K
Ryan
Ryan Clarke
RClarke@Parallax.com
Towards the very beginning of the program (in the ESC section) I do a check to make sure that I am receiving
a valid 1mS to 2mS signal from the receiver. If the signal is invalid (i.e. not there or out of range) everything
gets turned OFF to prevent a run away car on a mindless mission with it's last known instruction!
Basically you could apply the same technique.....
1) Read the HIGH pulse as well as the LOW pulse
2) Add the HIGH pulse together with the LOW pulse value
3) If the result from #2 is within the proper limits of the frame or "pulse window" from your receiver, then
your input channel is "ON" otherwise consider it "OFF".
'Pins Symbol PWM_Pin = 0 Symbol Forward_Control = 1 Symbol Reverse_Control = 2 Symbol Brake_Control_Pin = 3 Symbol Brake_Control = Pin3 Symbol DP_CLK = 4 Symbol DP_RST = 5 Symbol DP_DQ_Pin = 6 Symbol DP_DQ = Pin6 Symbol Signal = 7 'Constants Symbol PWM_On = 1 Symbol PWM_Off = 0 Symbol Operating_Frequency = 4 'MHz 'Variables Symbol Forward_Flag = Bit0 'w0.bit0 Symbol Reverse_Flag = Bit1 'w0.bit1 Symbol On_Time = w1 Symbol Off_Time = w2 Symbol Temp = w3 Symbol DP_Value = b8 'w4.low Symbol Shift_Out = b9 'w4.high Output Signal Output Forward_Control Output Reverse_Control Output Brake_Control_Pin Output DP_CLK Output DP_RST Output DP_DQ_Pin OFF: LOW Signal LOW Forward_Control LOW Reverse_Control LOW Brake_Control_Pin LOW DP_CLK LOW DP_RST LOW DP_DQ_Pin DP_Value = 0 gosub Set_DP ESC: pulsin PWM_Pin,PWM_Off,Off_Time pulsin PWM_Pin,PWM_On , On_Time Off_Time = Off_Time * 4 / Operating_Frequency On_Time = On_Time * 20 / Operating_Frequency * 2 If Off_Time < 1000 or Off_Time > 2500 then OFF If On_Time < 1000 or On_Time > 2000 then OFF Temp = Off_Time + On_Time If Temp < 2500 or Temp > 4000 then OFF HIGH Signal If On_Time < 1250 then FWD If On_Time < 1500 then REVERSE_BRAKE IF On_Time < 1750 then FORWARD_BRAKE REV: Reverse_Flag = 1 Forward_Flag = 0 DP_Value = On_Time - 1750 Brake_Control = 0 LOW Forward_Control gosub Set_DP HIGH Reverse_Control goto ESC FWD: Reverse_Flag = 0 Forward_Flag = 1 DP_Value = 1250 - On_Time Brake_Control=0 LOW Reverse_Control gosub Set_DP HIGH Forward_Control goto ESC REVERSE_BRAKE: DP_Value = 1500 - On_Time * Reverse_Flag DP_Value = DP_Value * 2 max 250 LOW Reverse_Control LOW Forward_Control Brake_Control=DP_Value max 1 gosub Set_DP goto ESC FORWARD_BRAKE: DP_Value = On_Time - 1500 * Forward_Flag DP_Value = DP_Value * 2 max 250 LOW Reverse_Control LOW Forward_Control Brake_Control = DP_Value max 1 gosub Set_DP goto ESC Set_DP: DP_Value = DP_Value * 51 / 50 HIGH DP_RST DP_DQ = 0 Temp = 20 / Operating_Frequency for Shift_Out = 1 to 9 PULSOUT DP_CLK,Temp next for Shift_Out = 1 to 8 DP_DQ = DP_Value / 128 PULSOUT DP_CLK,Temp DP_Value=DP_Value * 2 next LOW DP_RST return▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
