Standard DC Motor direct connection?
I've been playing a bit with my BS2 Homework board, and specially with servos... I have very little experience in electronics, I'm actually a programmer, and this takes me to a question, is OK to connect a standard 7.5volt motor directly to the BS2 output pins? if not, how can I interface that motor, since I want to control movement (forward and backward) from a program. I've tested the motor manually and it works in both directions.
thanks in advance
thanks in advance
<http://www.parallax.com/dl/docs/cols/nv/vol2/col/nv52.pdf> for larger motors (also applies to smaller ones).
<http://www.parallax.com/dl/docs/cols/nv/vol2/col/nv58.pdf> for a complex motor control project.
<http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv23.pdf> basics of motor control.
<http://www.parallax.com/detail.asp?product_id=27961> Motor Mind B product page - you can get documentation here
<http://www.parallax.com/detail.asp?product_id=30001> Motor Mind C product page - you can get documentation here
<http://www.parallax.com/detail.asp?product_id=30002> Motor Mind C Project Board
So , look fot H-bridge on the internet and see what you can find out .
Regards
Amaral
It’s simple for small DC motors and easy to breadboard.
JJ
I am no expert, but I have found this article VERY helpful.
- Jeff
P.S. This is what this part of the alphabet would look like if "Q" and "R" were eliminated.
I also wired an Hbridge, also somewhat difficult for a beginner, I thought.· This morning, I took delivery of this product.· Looks easy AND SAFE!· If 23.00 is in your budget, and your DC motor is lower voltage...· http://www.parallax.com/detail.asp?product_id=30052· I just got it, so I will not be able to hook it up till tonight.· But it looks pretty easy.
agentile
thanks,
Chris
You only have two choices with scrap box DC motors. Either see if they have manufacturer's names and model numbers on them, and track them down that way, or use trial and error with a variable DC voltage source starting at a low voltage (1-3 VDC) and working up from that. The smallest ones usually operate around 3-6VDC, as they get larger 6-12 VDC, with the largest ones operating at 12-24 VDC.
Theyr'e generally pretty sturdy, so a short term over-voltage usually won't hurt them. Good luck!
Bruce Bates
The only other way I thought of doing this is to connect them back into their RC car and use a multimeter, then run the motor and see what the multimeter says.
Do you think that this could work?
ps. sorry jmarcos for kind of taking over your thread!
Chris
ps. thanks for putting up with me as electronic circuits are very new to me!
Thanks for everything! [noparse];)[/noparse]
EDIT>>>>>
Ok, I've read the H-Bridge article, it looks interesting... I'll go that way.
BTW, any online electronics course you could recommend? Any software to aid?
thanks in advance!
Post Edited (jmarcos) : 2/4/2006 12:57:26 AM GMT
