Migrating Project From PDB To Carrier Board
I have a Parallax Professional Development Board, did a project on it with no problems. I used the programing port DB9 for serial com with another device. I want to move the project to a supercarrier board. So far I have had no luck I even went as far as to compare the circuitry of the two and the only thing I came up with was the carrier board has some caps off the ATN pin. Copied the ciruit on the pro board for ATN on the carrier board. The pro baord was pretty much striaght thru with some parrell stuff for USB ciruit. I get the intial requst for data to the device from the stanp but it fails as far as I can tell on the serin.
thanks wrig
Post Edited By Moderator (Chris Savage (Parallax)) : 1/24/2006 5:55:37 PM GMT
thanks wrig
Jon Williams
First thanks for the quick reply.
Yes I am using the programing port on the PDB to do serial com with another device.As far as I can tell the PDB has no caps on tbe ATN line, but the PDB does work. I took a spare super carrier board(SCB) and modified it to match the PDB but still no luck. There is some parrell stuff (USB) on the PDB which I did not add to the SCB. My goal is to get the working project on the PDB to the SCB.
wrig
Post Edited (Wrigly) : 1/24/2006 6:21:04 PM GMT
Jon Williams
