Addressing Bit Positions in SX/B
THE QUESTION:
I need to be able to set and get individual bit positions in a byte.· The SX/B help file says to do the following:
alarms········ VAR···· Byte(2)················ ' two bytes (16 bits)
fDoor··········VAR···· alarms(0).0············ ' front door
bDoor··········VAR···· alarms(0).1············ ' back door
patio··········VAR···· alarms(1).7
Using alarm as an example, I want to:
a = 1
x = 1
y = 7
alarm(x)··· = $00· ' clear the 2nd byte (this works)
alarm(x).y· = a·· ·' to set the 8th bit position within the 2nd alarm byte with a one
The SX/B seems to imply that alarm(1).7 has to be hard coded.· I need to be able to have variables in place of the 1 and the 7.
Does anyone know how to do it.
THE APPLICATION:
In working on the 1 Wire Search ROM routine, I need to store 64 bits of information.· A zero would indicate that there is no collision in this bit position and a one would indicate that there is a collision in this position.· This information will help in the next pass to determine which bits need to be toggled so that you can change your search pattern.
John J. Couture
San Diego Miramar College
a = 1
x = 1
y = 7
THE APPLICATION:
John J. Couture
The problem is that the SX doesn't allow a variable for bit position. You need to do something like this:
temp = 1 << y
IF a = 0 THEN
· temp = ~temp
· alarm(x) = alarm(x) AND temp
ELSE
· alarm(x) = alarm(x) OR temp
ENDIF
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
John J. Couture
