Parallax Servo controller
Question: does the servo controller limit a servo to only 180 Degrees?
If my microprosser tells the servo controller to cause·a sail wench servo to rotate 180 degrees in one direction and then back 359 degrees, does the servo controller only allow the servo to move 90 degrees one direction and then back 180 degrees?· Is it 90 degrees each side of center or 180 degrees degrees each side of center, or is it none of the above?
Bob
Bob
btw the servo controller sends pulses in the 500usec to 2500 usec range every 20ms
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
