STampDAQ Question
Buck Rogers
Hello!
Is there particular reason why the excellent StampDAQ product is currently aimed towards the BS2 family of devices?
It seems to me that it should work with any of the Stamps except for the original Stamp. For example, for what I do with my stamp, namely have the unit control breadboard constructed TTL based logic circuitry, the StampDAQ product would be perfect for tracking the sequence of data being manipulated by the Stamp, as it streams serial data pulses around.·One stream to the logic circuit, and then back, and then to the PC. (By way of example.)
·Just a thought.
Buck Rogers
www.gregg.levine.name
·It seems to me that it should work with any of the Stamps except for the original Stamp. For example, for what I do with my stamp, namely have the unit control breadboard constructed TTL based logic circuitry, the StampDAQ product would be perfect for tracking the sequence of data being manipulated by the Stamp, as it streams serial data pulses around.·One stream to the logic circuit, and then back, and then to the PC. (By way of example.)
·Just a thought.▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Buck Rogers
Jon Williams
You should be able to use StampDAQ with any of our products (except the BS1), as long as you are using 9600 baud. You're only seeing a BS2-IC code example because that's the most commonly-used BASIC Stamp.
It's a neat program and one of my favorites. I was really happy when Marty sent that to us one very late Friday evening.
Hello!
Ken I just had a look at the macro that is StampDAQ. It turns out that Jon is indeed correct here. The prompts for the baud rate include the lower speeds that the BS1 are capable of. Given the presence of the BS2-1C in everything else, I do agree with the rest of your statement.
Now for I am planning, if I can't get my application to work, let alone communicate with StampDAQ from BS1, at say 2400 baud, then I will cheerfully make arrangements to obtain the appropriate BS2, and carrier board. I've been looking at the super carrier
[size=+0]http://www.parallax.com/detail.asp?product_id=27130·[/size][size=+0]ever since it came out, (for the BS1 since there are mounts on it for that one), but it would work for the BS2 I would then be using. Of course the other problem is that the super carrier contains a wire wrap area, not a breadboard area. But that is easily solvable.[/size]
Buck Rogers
Now, you can still use the BS1, you'll just have to do a standard SEROUT of the strings and run them through a MAX232 or similar TTL-RS232 converter.
Jon Williams
