Building My Own Basic Stamp
Following on from what Matt Battle had started (reference http://forums.parallax.com/showthread.php?p=564291), I am looking to make own "Stamp Lite" that just has the pre-programmed PIC, EEPROM, Resonator and two resistors.
It would seem that the schematic from Weethet has a few mistakes (see http://www.weethet.nl/english/basicstamp2_homebrew.php).· I tried to combine the documentation from Parallax and the comments from Matt's discussion thread above hoping that i could get it to work.· Unfortunately, to no avail...· here is what I have...
The first circuit is the "Programmer" that I built on a small circuit board.
The second circuit is the "Stamp Lite" that is wired on a breadboard.
I didn't have 1uF electolytic caps, so I used polarized tantalums instead.
I know I need to check, recheck, and check my solder joints and physical implementation, but any ideas?· Basically, I am looking for a "sanity check" that if I wired everthing as show, it "should" work.· Thoughts?
pdf
690K
·· According to your drawing here you have the Vss and Vdd lines backward coming off the bottom of the board.· Not sure what you're connecting them to, but that could cause power problems.· Also, you have RX and TX coming off the bottom of the board, but where do they go?· The MCLR line, is it being pulled up?· It look like it is going through a switch, in which case it's floating.· That's what I see so far.
csavage@parallax.com
The "Programmer" is on the first page... the bottom plugs into my serial port on my computer... the top plugs into the header pins that are on the bottom of page 2.
I will also look into the pull-up on Pin8 of the inerpreter.
I think that /mclk was probably just a typo that I copied over from the weethet page.
Very interested in your simplified schamatic for an OEM using the FTDI USB chip!
Again, thanks so much... hopefully I will be able to test tonight!
