Digital servo
I have two TowerPro MG995 servos that I would like to use with my SumoBot. These are described as digital, coreless servos and there is no potentiometer. Can anyone tell me if these can be modified for continuous-rotation, and if so, some info on the required procedure would be greatly appreciated.
·1+1=10
Unless the prices of digital servos has dropped drastically, I wouldn't even consider hacking one. What's the advantage to hacking a digital servo over hacking an analog servo which is FAR less expensive?
Bruce Bates
Post Edited (Bruce Bates) : 1/20/2006 2:46:32 PM GMT
Digital servos are digital to provide more positioning accuracy. If you are going to hack it for continuous rotation, it being digital doesn't increase performance at all. I guess since this isn't made in the US, and that I've never heard of this brand, it's probably an inexpensive digital servo, so it might not matter much (if you can figure out how to convert it).
kelvin
This is purely a guess, but it wouldn't surprise me if they used a Hall Effect sensor. Not that that information is all that much help - sorry.
Bruce Bates
Like I said before, without having physical acess to the servo, I cannot determine the exact means of feeback used.
Another method that is used as Bruce has indicated is hall effect sensors. Since the gears are metal, a biased hall effect sensor (a hall effect sensor with a permanent magnet attached to the non-sensing side) can detect the passing of the teeth of a ferrous gear since the presence or absence of a gear's tooth is detectable by the small change in the electric field caused by the gear tooth's transversal of the permanent magnet's field. Again this method uses an encoder type methodology and is not easily hackable.
The best bet would be to investigate whether the controller supports reprogramming to alter it's stop values. Many digital servos support this but ussually require a dedicated programmer at an additional cost.
·1+1=10
"An analog servo updates the motor every 20mS (0.02 Seconds). So if it drifts off the commanded position it will take up to 20mS to send the motor another burst of voltage. So the motor isn't used to it's full capability. A digital servo updates the motor every 400uS (0.0004 Seconds). So the motor gets these bursts of voltage much faster. The more often a motor receives voltage, the more work it can do."
Digital servos provide better torqe and holding power.
At some point you need to look at the internal workings for feasiblity. Some servos actually have only a 180 degree arc of toothed gear.
Even if you have a full 360 degree gear, there may be a plastic stop that requires removal.
And if you could photo and post what you are looking at, the advice would be a lot less speculative.
Are you interested in trading these for more conventional servos?· I suspect someone would be happy to have the digitals for their original use.
Post Edited (Kramer) : 1/28/2006 5:43:13 PM GMT
I purchased 20 of these MG995 servos for use in my bipedal walker.· I opened the servo, and there IS a potentiometer, but these servos are REALLY cheap, and the potentiometer is equally as cheap.· They are NOT digital.· They are just standard, metal gear, servos.· They could easily be modified for continuous rotation.· In fact, the potentiometer is so shotty, that removing it altogether would improve the functionality of the servo.·
Just my $.02.· Later.
-Jay
A little late, but here is a picture of the MG995 Tower Pro Servo.· As you can see, there is a stop on the gear on the left.· Removing it should allow for continuous rotation.
Enjoy· Jeff
http://forums.parallax.com/showthread.php?p=660797
At the bottom of this thread you will find a link to the instructable of how I modified it..
I hope this helps!..
Happy Roboting!!!
I am just curious, were you able to use the MG995 for continuous rotation? I noticed some on ebay for cheap (2 for $25) but they say they are digital, so I am not sure they can be easily hacked. Has anyone actually hacked MG995's for continuous rotation?
-Tracy
