Programming BASIC Stamp with I2C
Hi I have and automation controller I built that talks 802.11b, but it just handles basic IO and analog conversion talking to program on PC remotely. I need to put a controller into it that runes a simple language (BASIC). This is the hang-up, how do I program it through my communications controller? My communications controller can talk rs232, but I have and i2c port with programming library already.
Is it passable to program the Basic stamp through the I2C?
Can I debug the basic stamp code? Can I Reset the stamp?
Is there a set of libraries I can include into my .NET controller application IDE builder?
![idea.gif](http://forums.parallax.com/images/smilies/idea.gif)
Jon Williams
While conceptually it is quite feasible, it is indeed an ambitious project in Assembler. On the other hand, the SX/B might make it come together quite handily.
Jon Williams
Did I miss something?
That would indeed create an I2C interface, but it would not allow you to program the BasicStamp via it.
From what I read, I thought he wanted to program the BasicStamp from a remote site. {I love the idea.}
You must use serial to program the BASIC Stamp. The BASIC Stamp can behave like an I2C master, but not an I2C slave.
Jon Williams
Your project sounds very tricky. Good luck -- I hope you can make it work!
Jon Williams
