I2C On A BASIC Stamp?
hello all, i'm a beginner. i need to know is it possible to program software I2C( inter integrated circuit) using basic stamp.
Post Edited By Moderator (Jon Williams (Parallax)) : 1/19/2006 4:17:25 PM GMT
Note -- make sure you add a subject title when you start a new thread so you'll get more responses (I fixed this thread for you).
Jon Williams
Post Edited (Kramer) : 1/21/2006 5:10:56 PM GMT
·1+1=10
http://www.parallax.com/dl/docs/cols/nv/vol5/col/nv115.pdf
At the beginning of StampWorks I suggest that one should download and study the part spec sheet before attempting an experiment (that's what we have to do an engineers) -- I've attached the 24LC32 docs for you to look at; it should also help you get going.
Good luck, and have fun.· Once you get the hang of I2C you'll be happy as it is easy to use and there are a lot of neat parts that use the protocol.
Jon Williams
the main purpose of this project is to connect between 2 basic stamp 2 modules. one will act as a master and another as slave. it will replicate a SCADA system(Supervisory Control Data Acquisition System).
any idea on that?
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv81.pdf
This should get you going and allow you to have bi-directional comms between your Master and Slave Stamps.
Jon Williams
Say a high is put on A0, the slave binary address will become 10100010, when converted to hex will become A2, the new address. Some chips use a different preset code address, check the specs.
kelvin
nuts&volts 81 is not that clear.can u please clarify on it?
Jon Williams
Could u explain the communication protocol that is used in this experiment of connecting the two stamps.That is the most important question.TQVM.
Jon Williams
which the connection is only involves, ser, Vss and 5V input. Could u please clarify?
Jon Williams
which the 7pin connector is nowhere to be found.
Let say if i get the parallel LCD, can it be connected to the board.
Please help.
Jon Williams
