Robot Arm, Servo controller...
Considering I started working on this 3 wks ago with no heavy prior knowledge of electronics or PIC programming, I am pretty happy.· I am not using a robot kit, building a larger robot from junked parts...· using servos, bs2 stamp.· Got my 12V DC drive and the 12v stepper motors that I had working!· Thanks to all who helped me learn about the IC's it took to do this.
Now, time to build an arm.· I purchased the·Parallax servo controller, and have 5 Parallax·continuous servos.
Which leads me to my next question...· For the arm, should I have not gotten "continuous" servos?· I try to research before asking for help, and in my reading the forums last night, I have the impression now that I cannot figure out the position of the servos from the servo controller·if they are the "continous" ones.
This is a BOE board, with a servo controller attached.· I am trying to plan the whole·arm out before I begin building it and adding it to the bot.
Again, thanks for all the incredible help.· I have learned more than I ever thought an old guy like me could learn in this period.
After I get the arm built, I will go back to eating and sleeping.
Generally speaking, continuous rotation servos are only used for driving wheels. You want ordinary servos to construct an articulated arm. I suspect Parallax will take them back, if they haven't been used.
Bruce Bates
Anyone have any ideas?· Anyone know of a Parallax distributor that has them in stock?
Could I use the mini servo instead?·
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXH318&P=7
"OEM NMEA GPS Module" Now available on ebay for only $17.49
Product web site: http://www.allsurplus.net/Axiom/
I'm trying to be loyal to Parallax, as they are my support structure in this....
I have wandered the web looking for a site that has parallax servos in stock...
Will the miniservos work?· http://www.parallax.com/detail.asp?product_id=900-00010 that is, can they be controlled from the servo controller board I bought from Parallax, and are they controlled exactly the same way?
Thanks for the help...
Servo City has great prices on servos.
www.servocity.com
Here is a comparable servo to Parallax's Standard servo, except it has ball bearing support:
http://www.servocity.com/html/hs-425bb_super_sport_bb.html
Post Edited (SN96) : 1/19/2006 5:51:22 PM GMT
Warning 56k people, this is a short video clip: sonyplaystationonline.com/ktekx/chronobot/completed%20and%20testing/MOV01441.MPG
Top view of the arm
Any standard analog R/C servo should work with the Parallax servo controllers.
Bruce Bates
Any standard servo will work. All standard servos work the same way. You send a pulse to the servo every 20ms and the servo moves.
Post Edited (SN96) : 1/19/2006 10:42:21 PM GMT
