rctime issuse
my project has a problem....
i am trying to read values from the lm35 temp sensor, a humidity sensor cap and an ldr, then display the results on the·velleman lcd (at least that works!!)
i am using a·stamp bs2, connected to the components via·the RCTime·idea, with 1k resistors and 0.1uf caps··(tried both ways round vcc + vdd) and i dont get any steady readings.
example of humidity sensor using debug screen (same as on lcd..)
cycle 1 = 7668
cycle 2 =·7383
cycle 3 = 6951 etc etc etc.....
any experts care to share a little knowledge?
best regards
krusty
cycle 1 = 7668
cycle 2 =·7383
best regards
krusty
Sid
br
krusty
TEMP IS READING 202 - 209 with cap on data and gnd pins.
humidity is giving readings of 5183 upto 7916.
these readings were taken over 30 seconds
the LDR also has a wide variation of readings, but this isnt a problem.
Sid
