very tough switches
Does anyone know were I could buy or how to build a switch that I could hit with a baseball bat over and over again?· How about a way to measure how hard the switch was being hit?
Bill Damerell
Bill Damerell
You want to activate a switch with a baseball bat, and you want to know how hard you hit the switch?
I'd look to the video game / entertainment industry for some inspiration. At Chuck-E-Cheese they have something like this - a "strong man" circus-looking game where a kid uses a big hammer to whack a round sensor. A red cylinder shoots up a red tube to attain a height and some lights and buzzers go off. This may be a pneumatic, non-electronic switch/cylinder setup, but I'm sure you could put a pressure sensor into the system. There's no baseball bat in this system, but it's the nearest I can envision to what you want to do.
It's Only A Stupid Question If You Have Not Googled It First!!
You may consider using an accelerometer attached to a fairly stout hanging weighted object. You could cover the target with something similar to rubber from a car tire. You can calculate the striking force from the accelerometer output related to the mass of the weight. My physics is a bit rusty. Considering the cost of some of the alloy bats these days, I would be concerned about damaging the bat.
It always made me cringe when I saw a Little League coach using a $200 C-Core bat to pound in a stake to chalk the baselines.
Lee Harker
Most of them are opto's. And they measure the difference intime between the first and 2nd opto going off....or the time difference in switches.
This is similar to those 'hoses' the transportation authority put across the road to measure traffic. If there's only one in your lane, they're measuring volume...if there's 2 in your lane, they're measureing volume and velocity.
What kind of bat were you looking to use?· Aluminum/Wooden/nerf?
Steve
I did a short stint in a "family entertainment center" (aka an arcade)....LOVED IT!
But things took SO much abuse....you were always replacing switches and lamps.
Skeeball was the most dangerous one....people thought they had to throw the hard wood ball at the hole.... Had the neon sign behind the game get wrecked a number of times!! haha
If you just took a bicycle pump and connected its handle to a mushroom switch, then you could connect the other end of the pump to the pressure transducer (if you have a well pump,you probably have a pressure switch that may work). OF course, this switch is only set for a single trip point. So, if they hit over Xpsi, it would trigger.
Most people have switches and opto's (and they're cheaper anyhow)...with this you can figure out velocity and maybe force....then use that with your game play.
Steve
Think outside the BOX!
