Homework board or Board of Education?
Which board would you get? The Homework board or Board of Education? I know that the homework board is half the price but·can find them·any where but on parallax. So which one?
Post Edited (Matt Battle) : 1/17/2006 3:00:29 AM GMT
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 1/18/2006 2:04:58 AM GMT
Post Edited (Matt Battle) : 1/17/2006 3:33:18 AM GMT
·· If you're new to the world of BASIC Stamps, you might want to consider the Discovery Kit, since it includes the "What's A Microcontroller?" guide and experiements to get you going on the path to learning the BASIC Stamp 2.
I am new to the BASIC Stamp world and need to learn as much as I can. At the same time though I need to save some money. I have most if not all the parts already that is include in the WAM kit. So what I am going to do is just download the WAM manual from Parallax.
-Matt
I think your first response probably needs a wee bit of editing...
I have the HomeWork board, and it has the built in BS2. You cannot upgrade the HomeWork board. Also I use a wall adaptor that has a 9v output and the end has a 9v snap connector and·it works great.
What made you choose the HomeWork Board?
-Matt
I am now hooked and have made this my hobby. I wish I would have spent a little more and got the Boe-Bot kit. You can upgrade microcontroller modules with the BOE (Board Of Education) and the Boe-Bot kit will keep you busy longer. If you are just looking to get your feet wet, then the "What's a microcontroller" kit from Radioshack is the way to go in my opinion. If you feel that you will probably want to get more involved, then the Boe-Bot kit is a fantastic choice also.
Yea, I bought the BOE "full kit" this morning. I hope I made the right choice. I wanted something that would keep me busy weeks to come. We shall see. I am going to do every activity that I can from every book that Parallax has on file. Hopefully I can get this robot of mine off the drawing board.
-Matt
What projects have you done with the BOE?
-Matt
·· Before I came to Parallax, and before I could afford to get any other boards I built everything on the BOE.· When I lacked room for extra circuitry, I sat the BOE at the top of a Jameco Breadboard (JE27) and jumpered wires across.· I have built dozens of projects on the BOE.· Of course, I still do for BOE Bot stuff, but now I develop on the PDB (Professional Development Board).· Once you've gotten a work-out on the BOE, you'll probably eventually migrate upward as well.· Stick with it and great rewards await!
I just bought the BOE and Stamp kit: http://www.parallax.com/detail.asp?product_id=28102. I already have most if not all the stuff that comes in the WAM? parts and text kit. So there was no need for me to buy that also. One of the "activities" I want to work on is getting the stamp to control DC motors. Any ideas?
-Matt
·· There are many methods of controlling DC Motors.· What you do depends on whether you need to be able to reverse the motor and whether or not you need speed control.
I don't want to control speed but I do want the motors to go at the same speed. What I want to control is to either to go forward or backwards.
-Matt
Quick question though. When installing the stamp onto the BOE does it go all the way down against the socket or does it stand up alittle bit?
-Matt
Post Edited (Matt Battle) : 1/19/2006 11:10:34 PM GMT
·· It should snap firmly into the socket, and there may be a small gap, but it should look as though it's seated fully into the socket.· If not, press firmly and evenly down on it to see if it snaps more into the socket.· If not, it's probably good.
9:37pm update:· I see now why you can't use a 9v battery while the BOE is connected·to the chassis.· Well, to allow my bot to move freely I removed the screw that was in the way for me to use a 9v battery.· Hope thats all good and dandy :-D.
-Matt
Post Edited (Matt Battle) : 1/20/2006 2:39:13 AM GMT
·· A 9V battery doesn't have sufficient current capability to run a BOE-Bot for very long.· You would likely drain it in a matter of a half an hour, if that.
Hmm, well I plan on buying the battery pack from you guys tomorrow and hopefully it will arrive by Monday. Until then i have one or two 9vs laying around. Hopefully I will be able to get some play out of my bot before it dies on me.
-Matt
