Transfer data from the Javelin to a database
In my school project, i need to recieve data from an RFID reader and transfer that data to a database.Is that possible using the Javelin microcontroller.If yes, which database will work with the Javelin.
http://www.parallax.com/html_pages/downloads/software/software_stampDAQ.asp
regards peter
Slightly more work but if you know Visual Basic at all, write a small App to read serial data from the Javalin and then use the VB app to talk to Access/SQL whatever.
The benifit would be the ability to process the data with VB from the Javalin
I believe John Williams has written a Nuts and Volts on it: http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv89.pdf
Cheers
james
