Arbitrary string length and LCD help.
I am looking for a snippet of code that will help me determine the length of an arbitrary length string.
The input is a string that is entered from the debug port.
I bought a Basic Stamp from Radioshack (one of those "What is a Microcontroller" kits) to keep myself entertained at work. It is working quite well. I haven't found anything to do with it as of yet, but I have a few ideas.
On a similar vein, what proceedures do you recommend for keeping the LCD at bay? I looked at the LCD code for included with the parallax 2x16LCD (which is very similar to my 2x20 display.)
The code for the test takes up roughly 2/3 of the available RAM. Do you have any suggestions as to better optimizing the code for the LCD? (even if all i can do is turn this into a serial LCD)?
Thanks for your suggestions.
Matt
Matt
It's difficult to give guidance on optimizing your program unless you actually post it....
Jon Williams
The issue is I'm having a heckuva time trying to control the LCD. Since I don't have much money, (the LCDs were something I found embedded in another device) I can't afford the luxury of one of the basic stamps that supports the LCDCMD functions. :P
THanks for the quick reply, when I come up with the code, I'll definitely post it here. [noparse]:)[/noparse]
Do yourself a favor, and take a run over here:
http://www.elabinc.com/
Punch up the EDE IC's and take a look at the "LCD Screen Control" IC's. The EDE-702 is probably your best bet, if you're short on money at the moment.
For about $9.00 US you can turn your existing parallel LCD into a serial LCD and remove 90% of the parallel LCD support code in your program. That gets replaced by a SEROUT statement whenever you want to display something.
Bruce Bates
I am very excited to announce that after getting some coffee in me yesterday that I was actually able to make sense of the sample Parallax code and I am now able to control my LCDs.. [noparse]:)[/noparse]
After learning how the DATA statements and how to READ from the memory I am making excellent progress in working with my basic stamp and should have a first version cranked out sometime this week.
One thing that I think I have bypassed for now but will probably haunt me later is that I haven't come across anything in the pbasic code that deals with strings other than the DATA and READ statements. My scenario:
I am trying to read from some user-generated text from a prompt created on the serial port.
Ex:
STAMP: Please enter your name:
User: My name is Matt.
Is there a way to sequentially read each letter from the string input listed above and process it individually? In BASIC, there was LEFT$, MID$ and RIGHT$ that would read certain positions from the string as well as LEN$ which would return the length of the string. Is there anything like this in PBASIC or do I need to write the memory of the string input to RAM before I can read it out again?
Your thoughts are extremely appreciated. I will be keeping this thread linked so I can pull off some of the information for those LCD controllers. [noparse]:)[/noparse] Although my LCDs have a 2x20 display and have pin headers with 2 rows of 7 pins each, I have already wired up an LCD "converter board" for my basic stamp and wiring up another converter shouldn't be too difficult. [noparse]:)[/noparse]
If yall are interested in the code for my parental lockout device of doom, please let me know, once I get all the bugs worked out, I'll post the code here. So far it's limited on features, but I'm up to this as of now:
1: 4 digit code stored in Flash.
2: configuration for switch behaviour: Toggle, On 1 seccond, Off one seccond
3: Serial port allows for password reset.
4: Will reset to last port state if power is lost.
Things I was thinking of adding:
1: Multiple codes (only admin codes can access configuration)
2: Some kind of logging feature... however with the lack of an RTC on the basic stamp, I don't think I can pull this off.. [noparse]:([/noparse]
Any suggestions?
2:
