Max6675
I am working on a project that deals with reading thermocouples. ·I believe the problem lies within my power supply somehow.·
I made a PCB with 20 MAX6675's on it that all read an individual thermocouple.· The MAX6675's are selected by shift registers and they share data and clock lines.· For initial testing purposes I have made a 5 volt power supply on a breadboard and connected that to my pcb.· My 5 volt power supply is a 7805 voltage regulator which is supplied by an "SR Components" class 2, 12 volt adaptor that I plug into the wall.· I have a capacitor before the regulator on the power supply and after it.· The problem I am having is my 5 volt regulator will get pretty hot at times.· If I plug in my AC adaptor, wait a few seconds, then connect my pcb to the 5 volts my regulator does not get hot.· However if I have my pcb connected to the 5 volt power strip and then plug in my AC adaptor, my 5 volt regulator will get pretty hot.· Do you know why my 5 volt regulator would be getting hot?· I don't believe I have a short anywhere, are my MAX6675's drawing too much?
Brian
Brian
It sounds like a problem of latchup, which can occur when there are two separate power supplies in the system. For example, I'm thinking the MAX6675s have one power supply and the BASIC Stamp and/or shift registers have a second separate power supply. Could there be anything like that going on? Do you have a multimeter to make some measurement?
Tracy Allen
www.emesystems.com
During my testing though, I unhooked the 15 volt and 6 volt circuits and regulators. My 5 volt regulator would still get pretty hot depending on which order I powered things up by(plug the regulated 5volt line into the pcb before or after plugging the adaptor into the wall). On the times it got hot, if I remember correctly, the board was drawing about 83mA, and on the times it didn't get hot it was around 2 or 3mA. I believe my 7805 should be able to handle about 1000mA, and all that I have powered on the board was the MAX6675's.
Is there a common ground among all three of those power supplies, and are they all powered by the same wallwort?
Is there a BASIC Stamp in this circuit and where does it get its power? What else is in the circuit that requires so many different power supplies?
Sorry for so many leading questions.
Tracy Allen
www.emesystems.com
I have not tested reading the thermocouples yet, but I will soon.· I have felt around on the MAX6675's when the regulator gets hot and I have not been able to find any of them feeling warm.· The three regulators all share a common ground and are all powered by the same wallwort, but as of now, only the 5 volt regulator is hooked up.·
I have not added my basic stamp to the circuit yet, there is only sockets where my other components will go.
Eventually the 5 volt regulator supplies 24 MAX6675's and 3 shift registers, the 7 volt regulator is used to power the basic stamp(BS2p40), and the 15 volt regulator is used for a 4-20mA control loop I have.· As you might be wondering, my projects goal is to control an actuator based on temperature data.· I have a full schematic I can post if needed, but as of right now my board only powers the 5 volt circuit with only sockets where the shift registers go like the attached·pdf schematic shows.··Everything on the 7 volt and 15 volt circuit have been disconnected.·
I would add that for the same reason, you should always set unused BASIC Stamp pins to be outputs (either high or low), or use a pullup or pulldown resistor. The whole point of that is to bring the pin to a definite low or high level. Otherwise the chip will consume excess power in a manner that depends maddeningly on the cosmic flow.
Tracy Allen
www.emesystems.com
Brian
