SX dead ?
inaki
Suddenly the SX28 refuses to set I/O pins to LOW/HIGH levels. I can program, run and debug·my programs but the I/O lines do not work at all ! I have tried the ports A,B and C and none of them works.
This is second time I find this problem on a SX28.
Does this mean that the SX is dead ? If so, how can this happen so easily ?
It worked yesterday and suddenly today it was dead at first try!
DIRL = %11111111
... but on the SX with SX/B, the equivalent command is:
TRIS_B = %00000000
-- just the opposite.
Jon Williams
Is it possible to blow up the SX28 just by putting power ON and OFF ?
I am working with the Professional Dev Board. Should I put the board OFF (with the provided switch)·prior to remove power ? Usually I remove power without setting the board OFF.
Also don't plug-in or remove the SX-Key without removing power. I fryed an SX-key that way. I plugged it in with the power on, and after a couple minutes it was burning hot. Hasn't worked since.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
