cheaper modems than the CH1786A
I want to use a modem in a future BS2 application, but the dang Cermetek CH1786A costs $59 a piece. I am getting a quote by email from them any time now for 2 of them. It will probably be highly unreasonable. My question, help me out please, Is there an easy way to interface with a non-winmodem-PCI card? Or do we know of any modems with the cermetek chip on it that we can unsolder. I can get a pci modem for $9(I didn't check the winmodem status). You can get an externel V.92 modem with callerID support cheaper than that single modem chip. The cermetek with caller ID is CH1786-C and who knows how much more that is. Does anybody know if I can simply solder wires to a low profile PCI modem and get it to work. I can't imagine it being that complicated. Except that you probably would need strobe circuitry to allow the modem to communicate all the time, not just at interupts on the PCI bus. Then it should be as simple as connecting RX,TX and power. Am I wrong? let me know. I don't want to pay over $120 to get 2 stamps to communicate over the phone. No DTMF is not sufficient, I actually need a modem.
What is the minimum acceptable baud rate for this proposed new modem?
Bruce Bates
Luckily my work had a bunch of old 2400 and 14400 USR modems sitting about, and I've been able to interface a stamp to them.
My only problem is in testing....I've only got one phoneline and a cell phone. So I can dial and receive calls with the stamp/modem....but haven't been able to set it up to transfer data!
Steve
Steve
Make your own telephone system with two modems on it, there is plenty of info on the net to whip up a power supply for one.
There are also black box modules that do the same thing....
If I remember its only 48vdc without the ring signal (90v ac on top of 48 dc power).
Bob N9LVU
I have seen those multi modem boards using socketed modem chips on Ebay. You might find some on Ebay right now...
Bob N9LVU
Ohh, okay. Then an external modem would be best, connected via a 232 level shifter...With PCI it would almost imposible to do it easily.
Bob N9LVU
If you click the 'more details' tab in the middle of the page, there's a link to the Data Sheet for the Socketmodem
Do you have any 'older' computer shops around? Heck, go in to a regular joe shmo one and see if they have any they'd be will to sell to get rid of!
I do still have my modems, but am not willing to part with them. I've plans for them down the line.
Also, you don't really need level shifters with them....well, I didn't. The stamps output TTL level rs232, which the modem seems to pick up just fine, but you DO need to remember to use the series resistors on your stamps rx lines (coming from the modems' Tx line) to limit the current so as not to kill a stamp pin.
As far as building my own telephone test system....I thought about it, but honestly didn't have the time to hassle with wondering if my 'make-shift' POTS was working or if it was something screwy on my modems/stamp....
I'll work it out eventually....I'll get the data jack/cable with my next cell purchase.
Steve
