Increasing the size of a EEPROM
I am using a BS2-OEM, with a socketed 24LC16B, and would like to replace it with an Atmel·24C64A. I thought they are pin for pin compatable, but the PIC16C57-HS/P does not recognize the 24C64A. Can you suggest how I can use the·larger capacity 24C64A, or any other EEPROM?
Also, I have an earlier posting, that you have given me an excellent answere for, that I would like to delete from your forum but don't know how to do it.
If your program doesn't fit into the original EEPROM, then you'll need to switch to one of the other BS2 versions that supports 16KB for programs such as the BS2SX, BS2PX, etc
Thank you
·· I don't think you understand, the interpreter (The proprietary code on the chip) is written to only address that much space.· If you want more EEPROM space you can either purchase or build an OEM BASIC Stamp 2e, 2sx, 2p, 2pe or 2px.· That is the only way.· You cannot just put a bigger EEPROM on and it works.· It's not like adding RAM to your PC.
csavage@parallax.com
