Hardware Communication Error With BS1 Serial Adapter
I'm getting a Hardware Communication Error when I try to download a program into my BS1 version 1.4 via my new (today) serial adapter. It asks me to check the serial connection and power supply. When I ask it to identify, that works fine. But, during the download I get the stated error message. I've tried another adapter (I ordered two) and I get the same error. The same cable works fine on the BS1 Project Board and BS2 Homework Board. Tried new batteries as well. What am I overlooking? I'm also using Editor Version 2.2.5
Frank
Frank
A "1.4" -- is that the BS1-IC?
Don't apologize...I'd of ask the same thing!
is the serial adapter connected to the STAMP right, with regard to the Index mark / "divvit"?
A "1.4" -- is that the BS1-IC? Yes
All of the above is correct.
Jon Williams
·· Are you using a Desktop or a Laptop computer?· Are you using a standard Serial Port or a USB to Serial Adapter?
csavage@parallax.com
Using a desktop with standard serial port and straight-thru serial cable. Again, appears to be a bad stamp as another one works fine. Never used this "backup" until now. Out $29 bucks. :-(
