ISD2560 voice recorder
Hello,
· I am working on a project which uses an ISD2560 voice recording chip, and I was hoping that someone out there has some experience with this.· I have built an example application·as shown in the datasheet, and when I record something, it does work, but the volume is so low that I have to scream into the microphone.· I put an LM386 on the output to boost the signal to the speaker, but this doesn't help.· It seems that the problem is on the microphone end.· I don't have much experience with electret microphones, so I'm not sure how to troubleshoot it.· Anyway, if anyone has any experience with these chips, I could use some advice.
thanks,
Andrew
thanks,
Andrew
http://www.parallax.com/dl/docs/prod/schem/SoundAppModSchem.pdf
csavage@parallax.com
···· Once again, you have been a great help to me.· This is exactly what I needed.
thanks,
Andrew
