FYI, Basic Stamp Editor works fine with Windows XP-64
UPDATE: It wasn't BSE after all. It was my video card which had a bad fan, thus causing my PC to lock up!
I know Parallax doesn't say XP-64 is supported, but I thought people might be interested to know.
I found that it runs perfectly fine unless 1 of 2 things happens.
1.) Your screen saver kicks on
2.) You close out the program
The problem does not seem to be consistent but it has happened to me 3 times in a row now. Nothing else on my system has a problem. This is a newly built OS (< 2 weeks old) with all the latest patches applied. The program works great while I'm actively using it. If I leave my machine for a while and come back, everything will be frozen and the display is slightly distorted. The last crash was when I exited the program. My monitor shut down and had a message about being out of sync. I have to hard reboot every time this happens.
Anyone else running XP-64 and having similar problems?
I'm using BASIC Stamp Windows Editor version 2.2.5.
John
Post Edited (Silicon Ghost) : 1/14/2006 7:13:04 PM GMT
John
Meh. Nothing here, move along.
It had nothing to do with the editor. One of my fans died in my video card. It was causing the video card to overheat and lock up the PC. It was just coincidence that this took place while I was using the BSE program.
Problem solved. Thankfully the video card is still under warranty.
- John
Jon Williams
- SG
