What are the two capacitors for between the BS2 and the PC Serial port?
Hello,
in the schematic on how to connect the BS2p to the serial port of a computer, it shows that there are two 0.1uf caps before pin3 and pin4 of the BS2. I was just wondering what's the use of these caps, and what would happen if i wanted to connect a serial cable directly to the BS2, without the caps. (i haven't tried it yet, but it's very tempting since i dont have any caps laying around :P)
Thanks again
Thanks again
http://forums.parallax.com/showthread.php?p=566239
csavage@parallax.com
So, as long as you disconnect the DTR line, or don't want to reset your BS2, or control the DTR line in your own code, you can leave the capacitors off.
Thom
