Need Master to enlighten grasshopper, in motor control world! — Parallax Forums
HamiHami Posts: 1
edited 2006-01-15 23:40 in General Discussion
Hi
New to this form, and need a little help, I looking to control 3 sets of two motors each, with 4 feed back switches, Love to monitor load on motors and switch based on load, and all of this using a laptop/PC based controller.· The application needs to be flexible, and attractive for the end user. The motors need to be around 130RPM, 12VDC, and aprox.70in Lbs.· With a 90% box.· Help, Help, Help, Help1
Hami
P.S. anybody know who carries or how to get a hlod of Croschopp, maybe a URL?
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2006-01-09 17:46
    Are you looking to implement something, or are you looking for off the shelf solutions?
    Ryan
    Ryan Clarke
    RClarke@Parallax.com
  • JavalinJavalin Posts: 892
    edited 2006-01-15 23:22
    If your looking for an IC to drive the motors with voltage and current measurement, have a butchers at National Semi's LMD18245
    www.national.com
    I believe NASA JPL use these or similar for their robotics drivers.
    You could (and I plan to) build a nice PCB with 4 of these (or more) and use an SX to control via RS232/RS485/i2c etc etc etc.
    James
  • Guenther DaubachGuenther Daubach Posts: 1,321
    Javlin,
    I'm not sure if this meets your requirements, just have a look at a board I once developed: www.parallax.com/sx/projects/projects_pwm.asp
    Greetings from Germany,
    G
