Baud Rate for Programming & DEBUG
Hello...
I am not sure if this is the proper way to ask this question technically.
Can the BAUD rate for programming and debugging the Basic Stamp be change?· I assume that the standard for programming is 9600.· Can this be changed to 2400?
I am not talking about the SERIN or the SEROUT commands, but the actual downloading and debugging of the stamp.
Deno
Deno
And remember to add a subject line to your new threads -- I fixed this one for you.
Jon Williams
·1+1=10
·· If the post is edited within 60 seconds or so after posting it doesn't show up.· The same goes for the original poster.· If you quickly edit your messages they don't show up as edited.· But if you go back a minute or so later they're tagged as edited by you.
csavage@parallax.com
I was looking at the RF modules sold by Reynolds Electronics:
RXLC434
TXLC 434
RXLC315
TXLC315
The maximum BAUD for these devices is 2400.· I thought using 2 different frequencys in a duplex fashion, I could transfer data back and forth between the computer and the stamp. The receivers do have a power down pin to turn off the local receiver to avoid interference, but it is uncertain if they would power down and power back up fast enough to capture the transmitted data.
I'll just keep looking and thinking and reading...
Thank you for your reply and I got in such a hurry, I did forget the subject line...I need some new memory in my brain?
Deno
