It's working!! BoE/Stamp controls braking on RC sailplane winch simulator
It's been a while since my previous post about using a BoE and Stamp to
control the braking on a winch for launching RC sailplanes. http://forums.parallax.com/forums/default.aspx?f=5&m=96533&g=96698#m96698
I've been hard at it, and the work has paid off. It's only working on the
simulator so far, but I'm very confident I can make the step up to full-scale
winch with no major problems.
The simulator I built to test the program is ridiculously simple. Just a little
DC motor from a junked RC car driving an aluminum wheel. The size of the
wheel puts the target for the sensor at the same radius it will be on the full-size
winch drum.
The simulator motor is switched on just before the Stamp is powered up
or reset. The speed curve of the simulator motor is much the same as the winch
drum after the launch when there's a lot of tension on the line. It starts out
with rapid acceleration at low speed, then less and less acceleration as the
speed increases.
I can vary the timing between starting the simulator and powering up the
Stamp to cover the range of speed and acceleration the Stamp sees during the
test runs. There were lots of failures early on, but the final version of
the program hasn't missed a beat in over fifty runs.
The bank of relays behind the simulator is the control system for the motor.
Two of the relays are used to reverse the current to the motor when the
"brake" is applied. The third relay is set up as a latching relay to
prevent the motor from running in the forward direction when the brake is
released. The other relay isn't used.
The LED on the BoE is the brake light. Just had to have one. Actually, it's
so I could tell if the Stamp was working if the simulator control system didn't
respond like it was supposed to. It would have made it easier to troubleshoot,
but I didn't need it.
The Hall-effect sensor with the moving magnet didn't work very well. The
values were scattered too much. I put an electromagnet (a small relay coil)
behind the sensor to act as a bias, and I put a steel setscrew on the
simulator wheel as the target. Using an electromagnet prevents "cogging"
between the magnet and target when the system isn't on.
The program uses "PULSIN" to measure the duration of the pulse from the
sensor on each revolution, and a "moving average" math routine to average
the speed measured on four revolutions.
The first part of the program determines if the drum is slowing or
accelerating. If it's slowing, the Stamp exits without doing anything. It
only takes about a dozen revolutions to do this.
If it's accelerating, the Stamp compares the moving averages until the slope
of the speed curve falls below an adjustable setpoint value. Then it counts
an adjustable number of revolutions before switching the motor on to stop
the drum. These two adjustable setpoints will make it easy to fine-tune the
program for the full-size winch
The Stamp continues to measure the speed of the drum as it slows.
When the duration of the pulse exceeds 1000 or a timeout occurs, the Stamp
switches the motor off, and exits. The drum is either stopped or turning
very slowly when the motor is switched off.
It's really exciting to see the BoE, Stamp, and simulator working like I
want it to. I can't wait to try it out on the full-size winch I'm already building.
Roger
winch drum.
speed increases.
Roger
Kudos on getting your winch project so far along, so quickly. Thanks for keeping us all informed with your progress. Merely seeing someone else, new to the world of Stamps, will give many the impetus to further their own thinking and efforts to develop bigger and more sophisticated projects on their own. We can all use a bit of vicarious motivation from time to time, just to keep us headed in a more productive and expansive direction. Yours was by no means an elementary project, especially for a first time Stamper!
Imagine trying to develop this automated version with something OTHER than the PBASIC Stamp. The utter simplicity, and reliability of the Stamp platforms make them a real pleasure to use, during all phases of project development. The cooperation, information, and support of this Stamp Forum can be a huge asset as well, as you have well seen.
When you get done with the entire project, and it's all in working order the way you want it to be, you might want to consider putting together some more formal documentation, possibly with some video footage, to submit to Parallax for inclusion on their Customer Applications page here:
http://www.parallax.com/html_pages/resources/custapps/main.asp
I'm reasonably sure they'd be happy to add your efforts to the growing list of successful major projects. Again, keep up the good work, and good luck as you reach your completion goal. Long live Stampers and Stamping!
Bruce Bates
