BS2px PULSOUT Ouput question on signal degradation.
Short and sweet...
I·want·to send a·PULSOUT signal out of a BS2px to possibly 80-100 other ICs but wondering if I need to buffer the output·pin first.
Post Edited (tdg8934) : 1/6/2006 8:34:55 PM GMT
It would certainly be good engineering practice to re-drive the signal.
·1+1=10
Since I don't have·any 7407's·handy, I was also thinking about using a ULN2003A with a 7404 inverter on its output to make it positive again. (Or even 2 7404's? "+- -+")
Any problems with these approaches?
If not, I'm sure I can come up with something. I have some PN200 High current PNP transistors, 2N3906 PNP and 2N3904 NPN transistors.
Post edit -- I've added another circuit, a real "how-to-do-it".· Use 2N3904s.· There's an inverter which will produce solid 0 & 5V outputs for the driver.· The output cap is more for voltage regulators, it's not really appropriate for any speedy switching (it'll act like a smoothing cap.)· Use a 1K to ground as a sort-of "pre-load".
Post Edited (PJ Allen) : 1/7/2006 4:32:49 AM GMT
Thanks for the circuit. However, in the mean time I did a search and found a buffer circuit posted by Beau.
http://forums.parallax.com/showthread.php?p=560954
I would assume the LOAD should be replaced by a 4.7K resistor and the output should be taken off of the collector of the 2n3904.
The circuits you provided are a bit·confusing to follow although well appreciated.·The second hand drawn circuit leaves the output inverted so that means I need to repeat the circuit twice to un-invert them? Also it uses 12v in the 2nd stage and I will only use 5v in my design. A problem?
Does a transistor emitter follower buffer circuit really provide superior fanout over an IC solution? What I mean is there any reason I would not want to use a 74HC07 or a CD4050 buffers (as it may just be a bit more convient to use [noparse][[/noparse]less solder connections]?
I want to make sure I can send a HIGH and LOW signal and also a PULSOUT signal to as many as 100 IC's.
Thanks.
Post Edited (Lead Test Engineer) : 1/7/2006 2:41:21 PM GMT
So, given that, why not rig it up on your protoboard?· That shouldn't take more than 10 minutes.· You mentioned you have parts enough for it.· If you have an o-scope, then more the better.· Then plug in more and more load (load resistors, don't use a POT) to increase the current draw from it -- test it out.· Not exactly the Labours of Hercules.
With regard to the circuit you mention in the previous post, it's like a ULN2003.· I thought you needed "fan-out" to a great many ICs, and I don't see how it will get you where you want to go (?).
Post Edited (PJ Allen) : 1/7/2006 4:12:16 PM GMT
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 1/7/2006 11:36:13 PM GMT
max. allowable sink/source current per group of I/O between Vdd pins = 50mA
I guess "per group of I/O between Vdd pins" means the sum total of sink/source for any one group (i.e. RA0-3 &·RB0-7; RC0-7 & RD0-3; and RD4-7 & RE0-7).· Meaning --·you can't have it all, all at once.
[noparse][[/noparse] Number of EEPROM write cycles = 10,000. ]
Post Edited (PJ Allen) : 1/7/2006 10:08:30 PM GMT
·· Correct, having all the pins sourcing/sinking their maximum would cause the chip to disspate more power than it is capable.
What I am using is·1 BS2px output going to 80+·CD4017 "Clock"·inputs using a PULSOUT command. I'm not using any SEROUT command or anything like that for 595's.
I have another BS2px output going to the 1st IC and the last IC only·(should not be a problem there).
I have another BS2px output going to a serial LCD.
I have the last BS2px output going to an SX28 (which acts as a matrix keyboard driver - see SX-Key Help examples).
The outputs are P15, 14, 13 and 12. P0 to P12 are not used.
I believe all I should be concerned with is the 1 BS2px output going out to all of the 80+ "Clock" inputs.
Do you believe a simple 2N3906 / 2N3904 type buffer will provide enough fan out to the +80 CD4017's (and also using +20 CD4081 AND gates for cascading the CD4017 ICs together)(100+ IC's)?
Thanks.
·· No, that's not how it works...If the 2N3904 can handle 100mA, then based on its hfe, it will require a certain amount from the I/O pin to deliver that current.· Beau Schwabe had a really nice write-up on transistor operation not too long ago.· Perhaps he could post a link to it or you could search Google for some information on using transistors.
Anyway, Lead Test Engineer, I think you need to estimate your current demand, come up with a·current budget.· What's the current drawn from a 4017 Clock In X 80, etc.?· That's the key.· Get out the DMM, rig up 3-4 4017s and drive them with a DC Hi-Lo·and find out, plan for worst-case X 2.
Maybe there's nothing to worry about, maybe the cruncher will be the practicalities of routing 80 wires.
I have used a CD4050 hex buffer on (2 buffers on 2 pins) on the BS2px sending PULSOUT on one pin and HIGH and LOW commands on the other. I have about 1/2 of the circuit wired up and working (40 4017 and 10 4081 ICs). I am testing the outputs at random points. I have soldered about 800 wire connections·now (next time I will build mini PCBs I can connect together).
I very happy I am still maintaining 4.93 vdc regulated down through the professional development board (using a 7.5 vdc 1 am wall transformer by Parallax).
I had no idea the CD4050 could handle 50 ICs for fan out.
I wire up 10 ICs at a time and test to make sure the CD4050 has not blown. All is working well with no overheating or any signs of problems. However, I did have to do some troubleshooting of some pinouts as 800 connections is bound to have a problem or two. I am taking my time (very time consuming) and checking and rechecking my connections.
If the CD4050 has a problem I may switch over to a transistor buffer solution or (can I double up on the buffers (e.g. 1 into another)?)
Thanks.
What a fan out from a buffer and a BS2px. I·read that·the 4xxx series ICs can handle up to 50 chips for fan out but it worked to over 100.
I have provided a work in progress picture showing about 800 feet of wire used. The end product used over 1200 feet of 22 and 20 AWG wire. It was wired to CAT-5 networking pushblocks with 100 terminal per pushblock. There are 400 connections per side with a total of 800 possible (circuit only goes to 712 outputs) (picture shows only 600 wired outputs) that are individually addressable with my BS2px software.
Finally this project is finished!
Post Edited (Lead Test Engineer) : 1/31/2006 1:25:17 AM GMT
·1+1=10
Well, you say your project is finished, and I see you did not heed the advice of using circuit boards instead of bread boards for the finished products delivered to your customer.
As a "Lead Test Engineer" you should be ashamed of yourself, and I believe your customer is in for the ride of his life when one of the connections intermittently becomes a little "loose".......boy try and trouble shoot THAT mess!
By your own admission you were "amazed" it worked. Me too! Instead, by using proper design procedures you should have been amazed if it had NOT worked.
Other than for a test-bed.... very unprofessional. Now that it's working, go and get the boards made and do it right!
Otherwise I hope my well-being never needs to rely on whatever "testing" you are "leading", and I'm sorry to say you're fired!
Cheers,
Peter (pjv)
As a proof of concept, your project is amazing, though.
You may think I've been overly hard on you, but believe me you have been a very frustating fellow to help.......you seem to pick the approaches opposite of the advice from the "seniors" in the forum. I suppose that is your right, but then you ought not ask for help or validation.
On Jan 1 you asked for assistance to reduce component/wire count, and the suggestions put forward would have made your project much simpler to design and build (provided you can write or copy and modify some assembler code), and you chose not to follow the recommendations.
Then you ask about the "legitimacy" of using bread-boards in a final product to be delivered to a customer, and again you do the opposite of the recommendations by not building a product that way.
Now that you have delivered this monster, again you are suggesting simplification; in other word re-doing a bunch of your work that could have been very much simplified (total chip count of 2 or 3 SX28, or just one SX48/52), and now you cite customer budgets and timelines as your reason for doing it the way you implemented it............the "hard" way.
Your whole project could have been implemented with just a single SX48/52 instead of that mess you created.
And as far as "customer approved" approach is concerned, you should not improperly let your client influence your design to become inferior just because it may save him some up-front dollars, which I believe in this instance was the exact opposite. I suspect the work could have been done in much less time with a single SX48/52.
I just can't figure you out.
Cheers,
Peter (pjv)
Post Edited (pjv) : 1/31/2006 11:34:56 PM GMT
