bs2 i/o pin output voltage
I am about to buy a bs2 kit for a little project I have in mind. Specifically, I want to control my lawn irrigation system. My idea is to use the output voltage of the I/O pins to drive a small reed relay which will switch the 24 vac needed to drive the sprinkler solenoids. To do this I need 5v from the I/O pins. Can the stamp manage that?
If it can't I guess I could always connect the I/O pins to an invertor and make sure the invertor has a vcc of at least +5v. My current prototype works this way, driven from the parallel port of my PC. But I'd like to build a stand-alone controller using the stamp.
Can the I/O pins be used to control relays, solenoids and other similar devices?
Yes, however, due to the demanding current and voltage requirements of some of these components, driver circuitry
will need to be used to properly isolate the I/O pins from harmful effects. For examples of this, refer to BASIC
Stamp I Application Note #6 and BASIC Stamp Article #6, “Silicon Steroids for Stamps”.
http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv6.pdf
Jon Williams
I'm using one right now for the same reason. The voltage from the pins on the parallel port drop DRAMATICALLY if I pull too much current from them (like trying to drive a reed relay), so I placed this invertor in between the port and the relays and bingo - it worked! Also writting zeroes means "turn on" - so when the PC is booted and the pins float high for a while, the sprinklers stay off. Not that it gets booted THAT often - this is a Linux box after all. (current uptime 33 days)
So, I can reuse the same idea (and invertor) for the Stamp driver irrigation controller. Cool.
