I2C usage (and other capabilities - advantages) on a BS2px
Now that I have both a BS2 and BS2px (and SX28)...I want to learn more about the BS2px's capabilities besides just the speed factor. I know that it has built in LCD functions but that is only for parallel versions of LCD (and I have a 2x16 non backlit parallel LCD, 2x16 backlit serial LCD and 4x20 backlit serial LCD). I don't think I will use parallel if serial has so many more benefits to it.
In particular, the I2C capabilites in the BS2px on what it is, why it is to be used vs other conventional methods on the BS2, etc..
I have the BS2p downloaded book but wondering if there was any other or better resources to look at.
Timothy Gilmore
Timothy Gilmore
http://www.semiconductors.philips.com/acrobat_download/literature/9398/39340011.pdf
This should be good weekend reading material.
Timothy Gilmore
One example-
TEMPERATURE MEASURING CIRCUIT
Say if you have an EEPROM hooked up to a BS2P. Suppose you have a BS2 stamp (master device)·that is measuring temperature via inputs, and it needs to store the values (in a EEPROM). It could communicate with·the EEPROM (slave)·with the I2C bus , and the BS2P programming is simplified using I2C commands..
Perhaps someone has some other examples?
Jon Williams
I appreciate your insight on this. I will read through the manual again over the weekend.
Timothy Gilmore
Additionally if you are not into C or Assembly, it is a much easier entry point.· I strongly suggest you read it first BEFORE trying to master manufacturer's PDFs.·
