From bench to real world...
I finally have my first *paid* project that uses a Basic Stamp! Woohoo! Probably a BS1, but could be a BS2.
The project involves hooking (3) 5VDC IR sensors to the stamp via less than 10 feet of 22/4 wire on each sensor. The sensors have a plus, minus, and Vout that is either high or low.
On the output side, I will be driving a relay that controls a couple of 110VAC solenoids.
Is there anything I should be doing to the circuit (input and/or output) to protect against possible noise, interference, coil kickback?
·· For starters you won't be able to control the relay directly.· You will need some sort of driver.· Either a MOSFET or a Transistor.· Really depends on the coil voltage/current.· But this driver will need protection against inductive feedback.· This is in the form of a diode.· If you're using a chip like the ULN2803, this is provided, if you connect it properly.
csavage@parallax.com
instead of mechanical relays, you might consider using solid-state relays instead. Fron the input side, they "look" like photo-couplers, i.e. you can drive them directly from BS output pins (with a current-limiting resistor in series). Most SSRs have an integrated zero-crossing detector, i.e. they turn on the load when the AC signal crosses zero, and this avoiding "spikes".
Greetings from Germany,
G
Post Edited (Jeff J.) : 1/4/2006 2:32:55 PM GMT
