BS2 With Printer Port
Since my primary computer is a laptop, corners were cut as far as serial ports go. Instead of having a 9-pin serial port, I have a 25-pin serial port (the kind you plug a printer into). Today I got a 25-pin female to 9-pin male adapter so I could use an old parallel cable that I found lying around with the Board of Education, but the Editor doesn't recognize it as existing. I'm curious if this has anything to do with the fact that pins 14 and 25 are missing, such that the pinout of the cable looks like this:
Is it possible at all for me to use a 25-pin cable with the BOE?
_____________________________ \ o o o o o o o o o o o o o / \ x o o o o o o o o o o x / ------------------------- o - Pin exists x - Pin missing
2. There ARE 25-pin serial port connectors out there. PC's and laptops don't use them.
3. IF you connect a parallel port to the BOE, it's not going to work. The BOE must be connected to a SERIAL port.
4. It is possible to purchase a USB to serial adapter, from FTDI, BAFO, or Keyspan. These are known to work. Belkin USB to serial adapters don't implement all the handshake signals the BOE requires. This is the recommended solution to your problem.
Don't use that cable. You need either a 25 pin extension cable (were all pins pass through), or an At serial cable that has reverse pins on ends;
(DB25 female---DB9male, hard to find) or get the regular At serial, and put thin gender changers on both ends (easiest to do)...
Bob N9LVU
Note all PC USB to Serial adapters also support this pinout.
