PINK email not working
Finally getting around to playing with my PINK.·
Going through the basic set ups and such...can see it....can read from it...can write to it...all great!...lots of potential.
But I can't send out emails.
I've gone in to my email program's setup and copied the same smtp settings and still no luck.
Now, I am required to log in to send email....how do I achieve this within the PINK?
Steve
Steve
John R.
8 + 8 = 10
A lot of ISPs are doing SMTP send authentication by requiring a recent POP access and authentication, because basic SMTP does not have authentication capability. Those doing SMTP (sned) generally require a recent POP login from the same IP address within the past 5 minutes.
How to deal with this is the reason for the discussion of how to add authentication to the PINK firmware. With basic SMTP it is not required- those that do require authentication may or may not be using the above mentioned scheme for verification/authentication.
Ryan
Ryan Clarke
RClarke@Parallax.com
Like, could the PINK send a regular email to the linux mail daemon, and then linux could forward it on to your regular secure ISP?
Steve
By definition the mail would not be secure, given that the mail sent from the PINK to the mailserver would not be secure (a possible point of attack)- would the mechanics of such a setup work- yes, if you could get sendmail or what ever working on your *NIX platform.
Ryan
Ryan Clarke
