What can you do with the SX?
theye
what can you do with the sx microcontrollers? i am new in this
Post Edited By Moderator (Jon Williams (Parallax)) : 1/1/2006 4:31:08 AM GMT
PS: Be sure to add a subject line when you start a new thread -- I fixed this one for you.
Jon Williams
Greetings from Germany,
G
http://www.parallax.com/sx/contest/design_contest.asp
Ken
PS: sorry if my english is bad i am from puerto rico and thanks for the help
csavage@parallax.com
PS: if you say to read a book tell me which THANKS!
The Art of Electronics - Horowitz and Hill
and also read
Introduction to the SX - Download from Parallax website.
Quite a lot.
I have been puzzling through the world of synchronous serial chips and it is very diverse. Each major manufacture has their own preference. The SX chips can handle ANY format [noparse][[/noparse]often in combination with other formats] while other devices cannot. Also, they can operate as a MASTER on any set of pin configurations and as a SLAVE with the only limitation being that Port B must be used for the Chip Select feature.
Having said that, you may not be aware of when an Sx is used simply because the end product is a hybrid rather than all one origin. The 'big guys' are not about to tout that possiblity because they want all your business. But with the SX you can pick the best from several origins and combine with the additional benefit of high speeds and flexible architecture.
http://www.sxlist.com/techref/ubicom/projects.htm
James Newton, Host of SXList.com
james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
Here is the WAM Kit: www.radioshack.com/product/index.jsp?productId=2117994&cp=&kw=parallax&parentPage=search
