angle sensor — Parallax Forums
angle sensor
TCTC Posts: 1,019
edited 2006-01-05 20:53 in General Discussion
I know this will be way off, but got to try. I am looking for a angle sensor for my 10" table saw. I make meny angle cuts and I would like to make them right. I just need something that can go from 0 degs to 45 degs. I am looking for something that I can hook up to a BS2 and display on a LED display using a MAX7219. And as I set the angle the display will tell me my angle.
T.C.
PS. Happy New Year
    edited 2006-01-01 06:11
    Hello,
    ·· For something with degree accuracy, you'll need some sort of encoder.· Depending on the resolution, you could calibrate it for 0-45 degrees or even 0-90 degrees no problem.· Heck, always starting at 0 degrees, you could use a contiuous rotation device and have 360 degrees if that were possible with a table saw.· =)
    csavage@parallax.com
  • TCTC Posts: 1,019
    edited 2006-01-04 01:44
    where could i get an encoder that might work?
  • KenMKenM Posts: 657
    usdigital.com for a good selection of encoders with various resolutions.
    Ken
