tank tread problem
Hi.. we just got the tank tread kit.· Unfortunately when we run the boe-bot the tread doesn't roll-over the servo/gear in a smooth fashion.. The gear teeth occasionally lose their traction on the tread... We have experimented in several ways including adding an additional roller. We now have 3 small rollers, 1 large roller in the front, and the main gear on the servo...
Any ideas in how to stop this problem of slipping gears...?
·· There is only one configuration and combination of gears you should be using.· Anything else won't work.· Perhaps you could take a picture of what you're using and post it, or one of us could post a picture of what you should be using.
csavage@parallax.com
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
One obvious thought is why are there so many small treads. Even just 2 pieces would be better. The 3 small pieces chained together add up to a lot of seams.
Does this make sense?
I can't think of any way to improve the situation.·
