Key chain remote
StarMan
Does anyone know of an off-the-shelf·momentary contact switch that is operated by a remote control.· I'm looking to pull up or pull down a Stamp pin remotely instead of pushing a button.
My google searches have·not yielded what I'm looking for.
Chris I.
Chris I.
http://www.parallax.com/html_pages/products/communication/rf_modules.asp
csavage@parallax.com
That will definitely do what I want but I think RF is a bit more than I need.· I was hoping to find an IR solution that is less expensive.· Sorry for not clarifying that in my original post.
Chris I.
http://store.qkits.com/moreinf.cfm/K6708
http://store.qkits.com/moreinfo.cfm/K6709
The first is the IR xmtr and the second is the IR rcvr.
Both pages show pics of both (same) items.
The sender is a key-fob sort of thing like it seems you desire.
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
http://store.qkits.com/moreinf.cfm/K6708 RESULTS IN ERROR
http://store.qkits.com/moreinfo.cfm/K6708 ADD THE O TO INF AN IT WORKS
73
SPENCE
K4KEP
I AM TYPING IN ALL CAPS NOT BECAUSE IT IS EASIER FOR ME TO READ AND TYPE AFTER 55 YEARS OF DOING IT THIS WAY, BUT BECAUSE I AM MAD AS HECK.· Just kidding (I've been waiting for the right moment.)·
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=RC-10&type=store
There is only one contact and it's not momentary contact but I bought one anyway.· I'll see if it's hackable.
Chris I.
What would be ideal for my project is a 5 volt, momentary contact unit.· On the circuit board inside is an 18 pin DIP IC labeled PT2272-L4 which is a latching RC decoder.· I works very well at 5 volts. The momentary compliment to this chip is the PT2272-M4.· If I could find one of these in the US, I could directly swap it and be on my way.· However, a search on findchips.com, digikey, etc. turned up empty.
Does any one have any search suggestions for finding one of these chips?
Also, I tried something else that worked a few times but quit.· From the data sheet for the PT2272, I noticed that the pin labeled VT goes high when the correct code is recognized.· This is a momentary thing during transmission.· So I tried connecting the base of a 2N2222 transistor to VT and·switching a 5 volt relay·(9202 05 30) with the transistor.· I used a 100ohm resistor between VT and the base.· It worked great for the first three tries and then VT stopped going high.· But I didn't see or smell smoke.·· The whole RC unit still works as it did originally.
Any comment or suggestions on how to proceed would be appreciated.
Chris I.
