Unkown parts — Parallax Forums
Unkown parts
ChrisPChrisP Posts: 136
edited 2005-12-30 07:32 in General Discussion
This is kinda like throwing a message in the bottle into the ocean but I'm hoping I'll get lucky. Went on a parts spree to my favorite surplus supplier today and while sorting through the place for the parts I was after I ran across what was probably a dual channel opto isolator. So far it looks like thats it, both sides isolated from each other, 1-4 pins grouped 1,2 3,4 but its reading 11 meg across what would be the LED from either polarity.
The only markings on it are......
___________
0459····· 2E |
················ |···· oh yes, its a white plastic case.······
·_______WE|
Pin1
Yup I'm a scrounge and about to head off for destructive testing to see what I can come up with, after searching yahoo, Digikey, Mouser and Newark no hits on the number for an optoisolator. Was just wondering if there was another place to look up specs on this critter.
Chrisp
  • cliedocliedo Posts: 6
    edited 2005-12-30 06:45
    check with some of the industrial electronic/ plc sites/forums, sounds to me like you have an ac input opto
    Post Edited (cliedo) : 12/30/2005 7:17:48 AM GMT
  • ChrisPChrisP Posts: 136
    edited 2005-12-30 07:08
    Destructive testing revealed its an AC input opto, you were right on the money. Also it looks like the output pinning is inverted. 8·neg 7·pos 6·pos·5 neg. So far I'm not even finding that configuration but still looking and thanks.
    Post Edited (ChrisP) : 12/30/2005 7:16:12 AM GMT
    edited 2005-12-30 07:22
    ill check at work and see if we have any optos and maybe get a manufactures spec for you
    Thanks, so far I've found the pinning, and under the glass its revealed as packaged in Thailand. I can use it at this point, it would just be nice to have the full data sheet on it. The only thing I've come across that schematicaly matches it is a Vishay part but the packaging dimensions differ from that one.
