BS1 Servo Controll
Hi again All,
I just recieved my BS1-USB in the mail, and let me say that it is really cool!
I went to controll a set of servos for a small robot chassis I made, and I noticed that because the BS1 is slower then the BS2 I am used to working with, its Duration unit is 10 us instead of 2 us. So after some math, I came up with 150 as the value I needed to pulsout to make my servo center. I also checked it against a fomula in the "Robotics with the BOE-Bot" text and this number seems correct. However when I try this, my servo quickly rotates in one direction untill it hits its limit, then just strains. No matter what value I try, It turns in the same direction and does the same thing.
Can someone help?
What value should I use for center?
Can someone help?
http://www.spiderspreyground.com/howto/prop-1
I was able to control 6 servos with one BS1 unit.
Hope this helps get you started!
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?"
VLG
To add another question, could fluctuating or insufficent supply voltage cause a servo to behave erratically?
csavage@parallax.com
Yup...you elaborated for me in another thread, so I just returned the favor [noparse]:)[/noparse]
I have never tried this, nor do I expect that I will, so this is just a matter of sheer of curiosity, good practice, and nothing more. With a BS-1 USB-connected, is it legitimate to use the parasitic power for the Stamp, and other circuitry as well, so long as you stay within the rated mA rating of the USB hub to which it's connected?
I've just not had all that much experience using the USB connection as a sole power source.
I realize it was designed with that in mind, however.
TIA
Bruce Bates
Borgel
