motion robot for video tracking.
I'm going to make a robotic platform mainly for a web cam to sit on. It will use continuous turn servo combined with a cog belt and pulley for turning the base of the device. However, I need a tilt axis so it can look up/down. I was thinking I would use basically the same setup just arrange it so the cog belt is vertical along with the motor and axis. My issue is if I use a single pulley and cog belt I can see a potential problem with the servo motor not turning from the weight applied to the axis... for example taking your hand and moving the servo would obviously move the servo armature eventually... I'm trying to figure out how much weight it would take... are there other robotic motors that can "lock". If anyone has experience with this type of scenario any input would be very much appreciated.
Take a look at these brackets, and how they can be very easily used to make a pan and titlt mechanism from two ordinary R/C servos. Note the arrary of pictures beneath the product:
http://www.lynxmotion.com/Product.aspx?productID=286&CategoryID=87
It doesn't get much easier than that!
Bruce Bates
kelvin
