Boe Bot's servos => problem
Hello
I'm french so sorry if my english is bad,
I just purchase a Boe Bot on Ebay, and i've got a problem with the servos.
In fact, when I run the following program :
The left servo go to Back direction, and the right to Front, and I don't understand why.
If somebody could help me, it would be very nice.
DEBUG "Program Running !"
counter VAR Word
FOR counter = 1 TO 60
PULSOUT 13, 850
PULSOUT 12, 850
PAUSE 20
NEXT
END
I know it sounds funny, but get a friend, stand next to each other and each twirl a string clockwise. Without changing direction of the string, slowly move so you both are standing back to back... look in a mirror and observe which way the two strings are rotating!
I knew I could do it by this way but is there a hardware solution ?
http://www.parallax.com/detail.asp?product_id=28125
csavage@parallax.com
MysteryCat... the concept I stated is correct... it is just that you need to make the switch of + and - on the motor inside of the servo... you will need to take the entire servo apart, desolder the motor, then solder it backwards. Sorry for the confusion!
The real way to deal with this is simply to understand that the two servos are installed mirror image.· Clockwise for one is forward, and reverse for the other.· One of the·concepts of having the microcontroller is to have the micorcontroller software deal with these issues, so that you can send it commands like "move forward", and have it take care of sending one servo clockwise and the other counter-clockwise (or anti-clockwise if that is easier to understand for our French friend).
Servos can probably be found at a hobby shop that sells radio controlled airplanes, cars or boats (not the "cheap toys" but the "real" models).· I'm guessing they should be around 20 Euros or so, but that's based on them being a little under 20 USD here.· I don't know what shipping, differences in volume, VAT and all that good stuff does to the pricing.· There are also instructions available from the Parallax site to convert a "standard" servo (like one you would get from a hobby shop) to a continuous rotation servo (like the ones used to drive the BOE-BOT).· I beleive this is covered in both the BOE-BOT manual and the WAM (What is a Microcontroller) manual.
John R.
8 + 8 = 10
You can check this web page for the Parallax Distributors in France:
http://www.parallax.com/html_pages/company/distributors/dist_europe.asp
They should be able to help you, and if they can't they can probably refer you to someone who can.
Bruce Bates
