Need someone who can build something for me.. Will pay
Hello
I am looking for someone to build me an item. I need to be able to enter a four digit number into a keypad and have a (1) LED light up. I need it to control 500 seperate leds that I will mount onto a 4'x5' map. I e-mailed Parallax and they sent me back a list of items i need to purchase. STOCK# 27238 STAMP, 2p40 / 27944, 4x4 matrix / 27943, 4x4 keypad cable, 27963, mem key and qty8 603-0001, 8 digit LED driver. I am a novice and do not understand how to assembly them. Is there anybody that can help me with this. Iam willing to pay for the service. It would be benifical if you lived in the New York area. Thank you Vinny Biondo
Post Edited (vinnyb1972) : 12/29/2005 12:57:56 PM GMT
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"I hope the goonwave is not vaporware"
Sid Weaver
Do you have a Stamp Tester yet?
http://forums.parallax.com/showthread.php?p=561568
http://forums.parallax.com/showthread.php?p=561515
Here are a few other LED, LCD and video related projects·I have submitted to the forum:
http://forums.parallax.com/showthread.php?p=561893
http://forums.parallax.com/showthread.php?p=561967
Custom project on SX Video Module (half way down):
www.sxvm.com
I live north of Baltimore, MD close to the PA border.
PM me or post your requirements.
BTW...Why 500 LEDs? A 5x7 LED matrix per character is 35 LEDs times 4 characters is only 140 LEDs (which I have already built in my Moving Display sign).
PS: I am currently working on another version using the MAX7219 LED Driver IC from Parallax that is working but needs work in to cascade more than 1 IC.
Timothy Gilmore
Post Edited (tdg8934) : 12/28/2005 1:55:15 PM GMT
Timothy Gilmore
Being that this is my first consultant type project, I took alot of critism for·my work and the design which may be unjust but my decisions were·based off of customer·needs and·schedule requirements. This project took 100's of hours and is not finished yet.·The customer is very pleased and will have a ceremony to demonstrate this to other Fire Departments in the City with a magazine article being written about this as well.
Thanks for everyones help in making this project a reality.
Timothy Gilmore
Post Edited (Lead Test Engineer) : 4/17/2006 12:18:28 PM GMT
If the client is happy, that's all that matters. I learned that a long time ago doing field service. Sometimes I didn't even have to fix the problem, just make the client (customer) happy.
How big is that map ? (Dimensions).
I hope you have all those cable labeled [noparse];)[/noparse] ?
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
Tim
Nice job, regardless of what anyone else might say! I just HOPE you've limited any technical support or warranties STOPPING at the PUNCH BLOCK, and nothing outwards, except possibly for out-lying product, if you supplied them. I'd hate like heck to think that you might be held responsible for obviously important in-field wiring, that was done by the customer, or the customer's electrician.
This is all the more important in this particular case, since human lives may be involved, if I read the purpose of this board corrrectly - to locate fires, hydrants, or other fire department resources or any like information in a graphical manner. If you haven't done so yet, I'd SURE give my lawyer a call, just to make sure you have ONLY SPECIFIC and LIMITED LIABILITY! We DON'T want to see anyone be a one-shot consultant, due to an open liabilty oversight!
Bruce Bates
<!--StartFragment -->
Post Edited (Bruce Bates) : 4/17/2006 12:39:11 PM GMT
My work is finished with the punchblocks. There is no liability issues from my end. However of the ~500 of ~700 LEDs currently wired up, they have only had 2-3 wires with problems that we have quickly identified and troubleshot no charge over the phone and are working as designed.
Thanks.
Nice project.....as far as critics go........I have noticed that there are never any critics while the page is blank. They only come out after someone has taken the initiative to create.
The finished project looks good.
I have to wonder though with all the hours spent and the incredible amount of wiring would it have been a good solution to use something like a video projector connected to a computer? The map could be projected and then a graphic of some sort blinking on the screen. It would make it possible to add or change call box locations with no wiring changes.
Just a thought.
Lee
And once you've got one working solution, ways to 'tweak' it to be better almost immediately come to mind. For instance, this application just cries out for some way to serialize the data, to reduce the number of direct connections needed, and the length of the wires. However, that could require many more boards on the back of the map. Your solution has the simplicity of that punch-block interface. Sure, it's a large number of wires, but conceptually it's simple.
Thanks for publishing the pictures here.
P.S. you could have 'bussed' the LED ground returns together, though...
Post Edited (allanlane5) : 4/17/2006 5:18:00 PM GMT
