Can someone recommend a stamp for this project please?
Hello,
I have been reading over this forums and website for a few weeks now and decided it was time to ask a question or two about my project idea. The goal of my project is to monitor, log and collect readings from sensors that monitor room temp, humidity, water temps, water levels, and PH levels in water also I want to controll relays for about 5 AC powered devices suchs as pumps, filters and heaters. I have plans to use the PING))) sensor to check water levels and to use the other sensors sold here to read everything but the PH which I am still looking into. Another main feature I am trying to fit in is an RJ45 network port so I can use to controller the system and read the data over my network. I have not seen any addons for 10/100 network cards so I am not sure how that would work out in the grand plan of things but it would be nice if it is doable.
Well now for my real question... I have not worked with any Stamp stuff before and wanted to do this project as a learning experience more than anything else and I plan to do it in phases rather than jumpping in head first and drowning in it heh [noparse]:)[/noparse] I am looking for someone to recommend the best Stamp controller for the job since the last thing I want to do is buy something that will not do all the things I need and since I am on a budget it is always nice to not over buy as well.
Thanks in advance,
Brann
Thanks in advance,
Brann
·· The best deal for starting out and learning the BASIC Stamp is the Discovery Kit (Linked below) which will also provide you will a tutorial kit (What's A Microcontroller?) and activities to learn.· Once you have mastered that, you can move on to the Applied Sensors kit (Posted second link) which will show you how to read sensors and record data.· Of course we also have many extra sensors and things you can play with, but I would recommend starting out with the Discovery Kit first.
http://www.parallax.com/detail.asp?product_id=27207
http://www.parallax.com/detail.asp?product_id=28127
csavage@parallax.com
So you think a BASIC Stamp 2 will do the job for what I am looking for? I was thinking about getting the Discovery Kit but after looking at all the different BASIC Stamp 2 options I just did not want to under/over buy.
If you want to communicate over the internet, you'll need to add the Parallax Internet NetBurner Kit available here
www.parallax.com/detail.asp?product_id=30013
·· It certainly sounds like, from your description that the BASIC Stamp 2 will do fine.· There are a couple of factors to consider when starting out new.
1) The majority of our code examples are based around the BASIC Stamp 2.· While some other module have additional speed, memory, etc. the·parameters·for many commands·need to be altered slightly for timing reasons.· This can often throw off a new user to the BASIC Stamp.
2) While the WAM Kit is cheaper, you also get more with the Discovery Kit, including everything that comes with the WAM Kit, a full BASIC Stamp Reference Manual, and a Board Of Education versus a Homework Board.· The BOE allows you to later upgrade your Stamp Module if you then decide you need more power.· The H/W Board has a surface mounted BS2 and cannot be upgraded.
3) The BOE is available in a USB version, whereas the H/W Board is available only in serial form.· This may not be a big deal for you, and in fact, we are currently back-ordered on the USB Boards, but it is a factor nonetheless.
4) Finally, you mentioned controlling AC devices.· Depending on the current draw, etc. of these devices, we may have a ready built product to handle this.· The RC-4 uses Solid-State Relays to control from 4 to 16 120VAC devices, up to 3A each.· This board will plug dircetly into the BOE Servo Headers for control.·
If you have any further questions or details of your system, feel free to post them.· Take care.
I recommend the BOE-BOT from Radio Shack. I like that it comes with a removable BS2 cheap that you can move to a solderless breadboard. The other cheaper kit (What is a Microcontroller one) has it's BS2 soldered to the board. I moved up to the BS2px later on and also the SX28 with a Professional Development Board "the ultimate".
Just my 2 cents worth.
Timothy Gilmore
http://www.parallax.com/detail.asp?product_id=30013
John R.
8 + 8 = 10
I'll be back after I get my stuff in the mail,
Brann
You can download a PowerPoint viewer from Microsoft, and one of the tutorials is available as HTML slides.
-Brann
Several of the features you want are already integrated on-board. But most importantly, it is a tried and tested data logger that programs in PBasic. I must admit that $199USD is a bit more, but with the RAM, the real time clock, and the temperature measuring already included, you have much less to put together from here and there. It certainly will flatten your learning curve a bit.
Try www.emsystems.com
