Optascope appears to have failed
I'm running an Optascope 81m with software v2.6.4. It appears to no longer detect input signals.
I was attempting to test a very simple BS/2 circuit that uses the AD592 transducer to detect temperatures. The circuit works fine--and functions as expected. However, regardless of where I attach the Optascope probes, the Auto Measurements windows display values of 0 volts. (I've tried both channels, and, I've tried all of the possible trigger src, trigger mode, trigger edge, run/stop settings.)
When I attempt a "zero calibration to ground", the two progress bars ("Overall Progress" and "Calibrating CH1") remain blank.
The COM port selection radio-button is green--indicating that I have a connection to the PC.
I've also tried uninstalling and re-installing the software. However,·the unit·still fails to detect any input signals.
Any thoughts?
Thanks!
--Donn
Any thoughts?
Thanks!
--Donn
csavage@parallax.com
Thanks!
--Donn
Post Edited (Chris Savage (Parallax)) : 12/23/2005 5:38:24 PM GMT
Yes. I do have another computer and was thinking about this last night: I'll install and give it a try.
Thanks!
