Lead-Free (Solder) Compliance
Hi All;
OK, so I'm not a "tree-hugger", but I'm also environmentally conscious, at least to a sensible level; I have no use for idiocity at any level!
This nasty bit of European regulatory skulduggery is finding it's way into my operation; as of July 1, 2006 my European clients can no longer import equipment that contains (among other things) solder. That is unless they are servers, communication equipment, and a short list of other items, none of which apply in my case. Of all things, mercury in lighting equipment is still OK.
What is the popular "short course" on how a small operator deals with these issues? Do you just fill your wave solder machine with lead-free solder, whatever that is; replace your hand-solder roll with some other material, and change your surface mount solder paste to what?
Can anyone give some insight as to how to deal with this on a practical level as only a small, but significant,·portion of my production is affected by this.
All practical help and·guidance will be much appreciated.
Cheers,
Peter (pjv)
Cheers,
Peter (pjv)
What to do?· You don't think this is just another way to force out pesky entrepreneurs and make the market safe for fat-cat corporationists, do you?
http://www.pb-free.info/laymans_terms.htm
You know, it's not just your solder spool, it's your pre-"tinned" component leads, too.
Post Edited (PJ Allen) : 12/22/2005 1:03:18 AM GMT
You mentioned paste, we use sn96 paste for our SMT boards and on·occasion used HMP solder paste. HMP·has terrible reflow characteristics. You could use sn96 for the paste but then you have to worry about the electronic components being subjected to higher temps. I'm not sure of other lower melting point lead free solders on the market. I will look into this.
I read a bunch on this last night, and the "what you can't do" is becoming clearer, but the "how to" is certainly escaping me at this point.
What a pain....
Cheers,
Peter (pjv)
As was mentioned ALL componets and the PCB must be lead-free too.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Forget about the past, plan for the future, and live for today.
·1+1=10
Here is a link to a very interesting article:
http://ehp.niehs.nih.gov/members/2005/113-10/innovations.html
Here is one paragraph from that link:
"The industry eventually selected a tin-silver-copper combination as offering the most reliability and ease to work with as a replacement. The formulation--95.5% tin, 3.9% silver, 0.6% copper--is also known as SAC solder, for the first letters of the chemical symbols of each of the elements (Sn, Ag, Cu). “Tin-silver-copper appears to have at least as good reliability if not higher reliability than tin-lead,” says Handwerker."
You still have the dilemma of certain components being subjected to higher temperatures even with the alternative SAC solder. Hand soldering might not be as bad, however·reflow or wave soldering could be a different issue.
