CM8880 DTMF decoding problems
Hello!
I have the CM8880 and am having trouble with decoding tones. The generating works fine, but the decoding only recognizes about half the tones I send (more specifically only 4,5,6,7,9,12,13,14). I am using the circuit and the modified program from this Nuts and Volts article: http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv7.pdf
I am using software to generate the DTMF and taking it from the earphone jack.
Thank you
Rafael
Post Edited (flyingfishfinger) : 12/22/2005 5:35:39 AM GMT
Thank you
Rafael
Rafael
I feel like i've been talking to mysef! LOL...
Never Mind
Happy Christmas
Rafael
Is this possible?
Rafael
I have not use CM8880 before, but I guess it should be similar to MT8870 IC
In a MT8870 IC,
you can use the TOE pin to mask all the 4 output pins or
you can use TOE pin as the indication if any tone is present.
Check out this website for brief introduction on the behavior of MT8870.
http://www.siongboon.com/projects/2005-07-18_dtmf_circuits/
Hopes this info helps.
Lim Siong Boon
siongboon@yahoo.com.sg
www.siongboon.com
