Smaller LCD??
Hello everyone,
I’m working in an electronics art project and I need a little help:
I’m looking for a small LCD Screen that I can program with my basic stamp. First of all it must bee very small (Give me as much possibilities as you can), and if possible essay to find – buy, and not too expensive. (Around 20 – 40 $).
I’m not very advanced in electronics, I have program command Hitachi 44780 based LCD displays 2X16. Please, give me us much information as possible (tell me for example the pin’s connections if they are different, external circuits – components I need to put…etc).
Thank you,![wink.gif](http://forums.parallax.com/images/smilies/wink.gif)
Felix.
www.othersounds.net
Thank you,
Felix.
www.othersounds.net
http://www.parallax.com/detail.asp?product_id=27976
csavage@parallax.com
sure i did, but i need something much more smaller . . . any idea?
Felix
or here:
(parallel) http://www.matrixorbital.com/index.php?cName=lcd-mop-character-lcds
(serial) http://www.matrixorbital.com/index.php?cName=lcd-character-lcds
Anything smaller will likely only be bare LCDs with no driver, not much use to someone without experience working with them.
·1+1=10
The lcds also have LED backlights.
***and the lcd controller chip is built into the lcd its self***
And they are graphical, so you can program a menu, like a cell phone.
Follow the link for more info. It has program examples, and detailed lcd data with pinouts and the like.
http://forums.parallax.com/showthread.php?p=559218
Post Edited (BPM) : 12/21/2005 1:25:42 AM GMT
After looking to the links you give me, the smaller commercial LCD of all seems the Powertip Model PC1202-A.
It’s 55.7 x 32.0 mm.
Do any of you know a smaller LCD that could bee programmed with a BS ??? , I’m looking for something much smaller (if possible), I only need to show a few phrases.
The most important side of the module that must be reduced is the width.
Thanks again,
Felix
www.othersound
Here's the link -- http://http://www.bgmicro.com/prodinfo.asp?sid=024498842592592620848810&prodid=LCD1027&page=1&cri=LCD&stype=2
·· IIRC the LCDBug uses the same size LCD Display as the one Paul mentioned.· It just adds a serial backpack to it.
[noparse][[/noparse] "backpack" = 1 STAMP PIN used; no "backpack" = too many STAMP PINs·used.]
