Suggestion For a Library
I'm pretty new to this group, but I really like what I'm seeing. To avoid repetitive answers, is there a library associated with the groups where we could just refer subscribers to a certain article title or number ?·I would like to contribute a couple of elementary remedies/procedures that I have solved myself, but, I·don't want to keep repeating everytime I see a related question. Thanks.
·1+1=10
Well, the forum archive itself is a library of sorts, with the URLs ("article title or number")·of every posting available to you for citation ("refer subscribers to").
Would the following approach work for you --citing your previous posting·which contains that·pertinent "remedy/procedure"
See, for example: http://forums.parallax.com/showthread.php?p=555755·for suggestions --from Paul, as well!-- on how to discover and use the URLs of your (and/or others') prior postings as citations.
This may not be exactly what you are seeking, but it seems to fit the need you described (above).
PAR
