Measuring Very High Voltage
I purchased an infrared kit years ago and have since misplaced all the documentation for it. What I can tell you is that it takes a 9V battery and steps it up to thousands of AC volts to power the IR tube. Can anyone please tell me how I can measure this voltage·? It's obviously out of the range of my meter. Furthermore the supply is arcing on the PCB. Can you suggest, by brand name, some insulating junk ? Thanks.
or...
HIGH VOLTAGE PROBE
Product Details:
The Tenma multiplier probe adapts most 10Mohm multimeters into a high voltage meter. Meets IEC1010 safety requirements.
40KVDC or peak AC, 28KVAC RMS (60Hz)
Division ratio: 1000:1
Input resistance: 1000Mohm
Accuracy:
DC:± 1% (1KV~20KV) ±2% (20KV~40KV)
AC: ±5% (1KV~28KV RMS, 50/60Hz)
http://site.mcminone.com/product.asp?catalog%5Fname=MCMProducts&product%5Fid=72%2D3040
HIGH VOLTAGE PUTTY 1 1/4 OZ. SILICONE RUBBER PUTTY
http://site.mcminone.com/product.asp?catalog%5Fname=MCMProducts&product%5Fid=20%2D975
When you get 1st Place in the "Darwin Awards", you're a Winner & a Loser.
Post Edited (PJ Allen) : 12/19/2005 2:03:28 PM GMT
All of this is in the realm of everyday Television Repair, so any electronics supplier that caters to that market will have a selection of probes and the high voltage putty.
Be sure to keep everything clean when working with High Voltage.
Dirt conducts electricty. HV attracts a lot of carbon as dirt.
Over the years I have been given several Color TVs that had completely 'blacked out'. In every case, all I did was to wash the insides, reinsulate the HV connections, and replace the 115VAC fuse.
Color TVs for a mere $10USD! {fuses, silicon seal, and spray cans of cleaner}.
http://members.tm.net/lapointe/High_Voltage_Probe.html
or....
http://cgi.ebay.com/FLUKE-80K-6-HV-PROBE-HIGH-VOLTAGE-PROBE-6KV_W0QQitemZ7573982376QQcategoryZ1504QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Edited (PJ Allen) : 12/19/2005 4:48:42 PM GMT
